LS1 cam questions
First off this is the Gen IV section and this belongs in the Gen III section but its ok, cam is a cam.
Second, why are you trying to use the stock springs? You are going to need aftermarket springs to help control your valvetrain with any aftermarket cam. The only cam you can run with stock springs is the LS6 cam and that, to me is a waste of money to just swap that in unless you are doing a cheapie forced induction setup.
