LS3 vs LS1 Engine Mount Bracket
Old 08-03-2013, 07:24 PM
schnellttz06's Avatar
Default LS3 vs LS1 Engine Mount Bracket
Well, I am putting a LSA engine in place of the LS6 in a C5 vette. It seems that there is a third bolt behind where the A/C bracket goes that is on the LS3 block that wasnt on the LS6. Now the LS6 bracket wont clear this extra protruding bolt hole. I am assuming I can just order a LS3 bracket for that side but I was hoping someone could verify the brackets are the same, other than having additional clearance for the extra hole. Hate to special order a bracket and it not work.
Thanks in advance.
Old 08-06-2013, 08:23 PM
In case anyone else is doing the same thing, the LS3 C6 motor mount bracket will clear the extra bolt hole on the newer blocks. LS1/6 on left LS3, LSA on right.
Quick Reply: LS3 vs LS1 Engine Mount Bracket
