DYNO RESULTS!! 402 build. Which cam for Trickflow 255 heads
I would think the TEA/TFS 235s would be the ticket for the 402. From what I've read, you really need a minimun 4.065" bore for LS3 heads to shine. Reguardless which heads you decide on, have a custom cam spec'd by either Martin @ www.tickperformance.com or Patrick G
Check out the build below. LS3 416 w/ported LS3 heads. Dyno graph post 27 IIRC
https://ls1tech.com/forums/pontiac-f...8-build-2.html
You said in a previous post you go to Pat G's shop for dyno testing, why not get him to spec you a cam? You're using the shop of one of the better cam guys in the country and then asking us what cam to use!?!?
The cam drives very similar if not better than my eps 230/238 when I had the LS3. The car is an absolute monster from a roll. I will post the dyno sheets up later and maybe take some pics . I ve been told and it sure does feel like the car is good for 10s on motor. The question is whether or not I can get it to hook.weighed the car last month and it came in at 3060. I still plan on adding drag wheels and a lightweight battery. If you are anywhere near the Texas area, I highly recommend Patrick G for tuning. He is worth every penny and has proven to me for a 3rd time that he is the best IMO. He and Kurt are very professional and always got some nice projects in the shop getting major upgrades. Thanks again to Martin as well for the custom cam. It got me just where I wanted to be. In the future I may send off my heads to TEA for additional porting to see if it will help me chase every last hp
#34
