Lq4+ls1?
Old 10-25-2013, 01:21 PM
Pseudonym's Avatar
Default Lq4+ls1?
I am going to pick up a complete LQ4 from a 2000 GMC truck and an 1999 LS1 with damage pistons and bad block, but everything else is in good condition, ie: crank, heads, connecting rods. The cam will be the polluter from Tick Performance, and it will be carbed. How can I Frankenstein these two motors to make the best combination without spending much money? It will be going into a 1968 Camaro with a TH400.
If this is in the wrong section, I am very sorry. I wasnt sure where to put it.
Old 10-25-2013, 05:37 PM
KCS
Moderator
KCS's Avatar
It would probably be in your best interest to use the heads and oil pan/pickup from the LS1 and use it on the LQ4. I'm assuming the LQ4 has 317 castings, which have a larger chamber than the LS1 heads. Using the LS1 heads will increase compression.
The oil pan and pickup tube is probably needed to clear in the Camaro chassis.
Old 10-26-2013, 04:44 PM
iliveonnitro's Avatar
You'll also want to use the front accessories from the LS1. The accessories on the LQ4 stick out further. Keep the LQ4 crank.
Old 10-26-2013, 09:04 PM
LS1MCSS's Avatar
That LQ4 will probably have the longer end on the back of the crank so you won't need any type of spacer to use the TH400 tranny.
Old 10-27-2013, 10:35 AM
Pseudonym's Avatar
Thanks everyone!
Quick Reply: Lq4+ls1?
