6.0 Motor Mount Level?s
Old 01-14-2014, 01:11 PM
rodnut's Avatar
Default 6.0 Motor Mount Level?s
Is there a difference in the location of the mounts from one side to another on a 6.0 block? (Same height)
Is one side (motor mount location on the block) higher or lower than the other.
Like a small block mounts are the same on both sides as in location and height.
Do I need two different length frame mounts to correctly install a 6.0 motor?
Clear as mud I'm sure, but the question has come up.
FYI I'm putting a 6.0 in a 94 s10 frame
Old 01-17-2014, 09:37 AM
iliveonnitro's Avatar
The hole locations are symmetric on each side of the block. What is the exact issue you're having?
Quick Reply: 6.0 Motor Mount Level?s
