erl sleeved ls2 question
Just curious how much erl ls2 sleeved can be max bored to na.
Also how much can it be bored and still be safe with 200 shot
its erl 434 right now but needs bored out . Need opinions please
Our Superdeck I blocks can be bored out to a 4.200 bore and our ERL Dry SLeeve blocks can be cored out to a 4.185.
If tuned properly you should be ok with a 200 shot on each of those. How much needs to be honed out on the 434 ci?
Needs to go to a 4.160 or 4.165. Figured might as well figure out best deal I can do and still get more cubes and still spray 200. Cylinder 6 and 8 were slightly out of round. So gotta be fixed. So what cubic inch 4.200 amd 4.185?
I know a 4.185" is a 454ci when combined with a 4.125" stroke...and I think the 4.200" bore with a 4.125" stroke gives you about 457ci, but that is just a rough calculation....
No need what so ever to take it to the max bore for a few cubes. That leaves no rebuilds left on it and basically worthless if you part the engine out down the road. Take out enough to get the cylinder where you want it and no more.
Im not going be real hard on it. Like its mostly going be na.. see few 200 shots maybe couple 300. No more than thst tho. Its going be road raced and some drag. I dont want max out bore but was curious on how big it can go. I wanna do 200 shot safely
At 12.6 cr now. Thot abt 13.1 cr but with 200 shot.. every once while. Just dmt want to much cylinder pressure being bored out to much. Want to be safe.. any thoughts? ?
Its a ls2 block erl sleeved. And were prolly going with a 4.165 bore. So theres room later. Just womder if 13.1 compression wouod give it that much more cylinder pressure with the 200 shot than the 12.6
