Need help picking out a cam
Old 02-20-2014, 12:06 AM
6.0ls mustang's Avatar
Default Need help picking out a cam
i have a lq4 stock lower with 243 heads and a fast 90/90 intake. I also have comp 1.8 rockers
Old 02-23-2014, 02:48 PM
A.R. Shale Targa's Avatar
Call Geoff at EPS or click on his sponsor link to the right >>>>>>>>>>
If you already have the rockers then a low-lift mild design lobe profile will be
needed along with dual valvesprings in order to prevent the lift from getting
too high as well as preventing valve float. Those rockers are considerably
heavier than the stock rockers...which most modern aggressive cams have
been designed for.
Old 02-24-2014, 05:12 PM
andy9743's Avatar
call martin @tick you will not find a nicer guy to assist you
Old 02-24-2014, 06:54 PM
ez2cdave's Avatar
Also, Patrick Guerra, aka "Patrick G", is another good person to contact about the proper cam for your combination.
Quick Reply: Need help picking out a cam
