Dry to Wet sump conversion
I am converting a long snout to wet sump using a scoggin dickey spacer. I plan on running an ATI dampner and would like to pin the crank for it. My question if whether or not i will be able to pin it with the spacer installed and can the pins be later removed should i decide to convert back to dry
