FAST LSXR MAP Plug
FAST LSXR MAP Plug
I got a used LSXR intake and the MAP sensor location on the back has already been drilled but I want to use the front location. Any ideas on how to plug it? Is there a block off plate out there?
If you have pics on how to do it that would help a lot. Thanks!
The problem with that port back there is it sticks out and is very thin. You'll need to grind the extension off and actually get to the base of the plastic. I do believe a 1/4 NPT is what you'll need along with teflon tape. If that scares you, go buy a dowel pin and epoxy it in.
