Oil pan help
Oil pan help
Building an LS3 from scratch, and I want to know if a Chevrolet Performance oil pan will have any issues with a 4" stroke as the part description says it isn't clearanced for a stroker... Also, Will said pan fit into a 2nd gen fbody? or do I need the conversion pan...
Both the LS2 and LS3 pans do have to be clearanced for a 4 inch stroke. Not a big deal, just a little die grinder time. You will also have to either use spacers on the windage tray or buy a MAST #401-015 stroker windage tray. (Colorado Speed has them) Never owned a Camaro but I imagine a Vette pan would fit since it's the go to pan for a lot of engines swaps that need clearance.
