Anyone use 15850 Comp Cams Lifters?
What do you guys have to say about the short travel COMP CAMS LIFTERS?
http://www.compperformancegroupstore...Category_Code=
Rep states they are good lifters when preloaded 2.5-5k. I am currently running the comp cam aftermarket lifters, which have been really good and performed well, until I turned up the valve spring pressure.
I have PAC12070s @ 1.74" install ht. Was thinking going solid, more for stability than power. The cost is off the charts to get there though.
Also, looking at adding adj TD's by Comp to firm things up.
NOTE: If you have a lifter that you have used, please post up the cam specs/spring pressures/heights and type of spring/cam/rockers used.
Also, Morel 5206 vs 5294?? One better than other?
