Did a compression test - How's it look?
Old 10-29-2014, 07:22 PM
Teerump's Avatar
Default Did a compression test - How's it look?
Have a 2006 Pontiac GTO LS2 6.0 Motor.
We did a compression test today.
Here are my numbers, tell me what you guys think. The car is completely stock with 74,000 miles.
I'm going to post the first crank and last crank, we let it crank 5 times.
1st crank is in parenthesis.
#1 (30) 150
#2 (40) 148
#3 (40) 155
#4 (40) 150
#5 (30) 152
#6 (40) 150
#7 (35) 148
#8 (35) 150
Also, you guys know of a way to test if there is any clogging of the catalytic converters?
Old 10-29-2014, 08:32 PM
Tainted's Avatar
I'll add that prior to doing the test we seafoamed the car and engine was cooled down as well.
Old 11-07-2014, 07:53 PM
gnx7's Avatar
That's about as even as it gets..... run it. If it was cold then the numbers are lower than if it was warmed up.
Quick Reply: Did a compression test - How's it look?
