Knock Sensor Connectors
I have a 2006 5.3 with block mounted knock sensors and a 2004 harness with intake valley mounted sensors. Were can I get the connectors for the block mounted knock sensors?
Thanks
Thanks
google "z06 connector end views" you'll hit a link to the efilive forum with a pdf of all of all the connectors including the engine connectors with part numbers. The connectors are available from a number of sources in various levels of completion ie just the shell to a pigtail.
