Good stock piston replacement
MAHLE Motorsports Power Pak kit
Forged pistons, pins, rings. Two over sizes. Reasonably priced. Uses stock rods.
LS3 / L92 FLAT TOP
1.5, 1.5, 3.0mm File Fit Performance Ring Set included 70cc
376 ci 4.065 Bore L92340065F04
376 ci 4.070 Bore L92340070F04
378 ci 4.075 Bore L92340075F04
Available from many vendors. Mahle is the supplier of the OEM LS3 cast pistons.
LS3 / L92 FLAT TOP
LS3 / L92 FLAT TOP
LS3 / L92 FLAT TOP
