Removing pin circlip locks!
Old 02-06-2015, 08:04 PM
S10xGN's Avatar
Default Removing pin circlip locks!
Got a set of LS7 rods that I need to remove the pistons from. I've Googled all afternoon and only found one vid on You-tube, and that was from a guy that milled a hole in the piston in order to snag the clip. The stock pistons do not have any kind of relief slot to get a tool into, don't want to ruin these as they are almost perfect. I did see this Kent Moore tool but don't know if it's what I need. Would most shops be able to handle these rascals?
Old 02-07-2015, 11:41 AM
KCS
Moderator
KCS's Avatar
Most people I know just mill the pistons like you said, just deep enough to get a small screwdriver or pick under the clip.
Old 02-07-2015, 07:59 PM
S10xGN's Avatar
I was planning on flipping the pistons, don't need 'em Would that make potential buyers shy off? Where in the boss would it have the least impact on strength?
Thanks!
Old 02-08-2015, 12:05 PM
KCS
Moderator
KCS's Avatar
Thanks!
I think it's an upgrade if done correctly. I have milled into the boss off to the side. I try to mill a small enough hole to fit between the gap in the clip so it doesn't damage it.
Old 02-08-2015, 08:12 PM
S10xGN's Avatar
Thanks! Guess as long as I fully disclose the "mods" and let the buyer make up his mind...
Quick Reply: Removing pin circlip locks!
