Lifters tight in new block
How snug are lifters suppose to be in the lifter bores in a new block? I'm have a set of Johnson link bars and when I put them in the new block they slid in but not very easily. I figured they might just need to be run and wear in and I wanted to confirm this. They are not super tight but if they stayed this way I would not be able to use a pen magnet to pull them up or anything.
I didn't have a bore gauge. They don't stick or anything in the bores. They are just snug. They move up and down freely when I turn the crank over. Maybe I'll get a bore gauge and check it out to confirm. 0.0015 is a pretty small gap so that could be pretty much where I'm at and I'm just being paranoid
In that case I will just run them, was just thinking if I did a cam swap I wasn't sure a pen magnet would be able to grab them but they don't have oil all over them yet either
Are you using an aluminum block?
Measure it by all means, but if its neat sliding fit at room temperature it will be perfect at an engines normal operating temperature.
I was just test fitting them dry, I'm sure after I simmer them in some oil and use some assembly grease they will slide better
Let me know how they fit in the block after you lube them a little. They should slide in with no effort, as clearance should be around .0015". I've ran across a few issues with factory GM blocks, usually roundness and taper. The lifters are ground to .8421"-.8418"
lubrication first...
Just use them, don't put lifters in their bore dry, if hydraulic deep them in a jar in oil overnight or two then install them wet. be sure to squirt cam lobes with oil before you drop them in.
