Crank keyway and front seal
I have a aftermarket crank that has a keyway grove all the way down the snout. Right now there is 2 keyways installed on it. What is the proper way to install the front cover around them? I was thinking I will remove the end one and then put it back on after the cover/seal is on. Can I cut a keyway to size? Do I need to fill in the groove with something like silicon so it doesn't leak around the seal? Thanks in advance
