L99 to LS3 VVT&DOD Delete Help
Guys, need some help i have a L99 converted to LS3 spec's my tuner removed all the VATS / Security the motor starts then shuts off its throwing a bunch codes mostly emission code and fuel level sensor codes the key codes i think the important / bad code is "P0010" does the tuner need to disable the VVT options ? does this sound like it could be my problem ?
P0010 cam shaft sensor isnt this for a l99 which i dont have anymore ?
P0443 evap code
P0449 evap code
P0452 evap
P0463 fuel level sensor
P0557 brake booster pressure
P2068 fuel level sensor
VVT Delete
DOD Delete
New Valley cover LS3
BTR Cam Stage II with springs
Alll New Lifters 16
Steve
P0443 evap code
P0449 evap code
P0452 evap
VVT Delete
DOD Delete
Alll New Lifters 16
Steve
