curiosity lunati cam and tfs 205 heads
Is a lunati voodoo high lift series cam 219/223 .625/.625 112/108 too much on the tfs 205 top end kit? This engine has wiseco 11.6 pistons 3.80 bore but come in at 11.8:1 on this build and ls7 lifters and lsxrt intake. On the tf Web site the flow chart ends at .600 lift but the spring part number says .650. Also they seem, on the chart at least to max at I think 284 cfm at .600. This cam has a broader rpm range than the tfs 220/224 .575/.575 112/108. 2200 to 6400rpm vs the lunati at 1800 to 6400 rpm
Gmhtp magazine tested that 219 cam... It made great power EVERYWHERE in the powerband. I say you made a good choice on the heads and cam setup. However I would recommend you look into a better litter than a LS7.
