"USED" Gen IV rod bolt TQ specs ?
OK, I'm ready to TQ my rod bolts back down after widening my ring gaps. The spec I found was 15 ft lbs - first pass, then 75* on second pass. Is that the right specs for USED BOLTS ? usually, I always thought the rod bolts were "angle tightened" on the first setup to stretch the bolts, then any retorque after the initial built would be to a " LBS TQ SPEC ". Steer me right, guys.......
Here you go. They don't give *used* specs in the book. That I can find that is.
