468 Lsx cam help
468 Lsx cam help
Need some help on cam selection. Building a 468 LS with 11.7 compression. Gm CNC ls3 heads, truck intake. Max RPM is 6000 as its in a airboat. Need something that comes in early and pulls hard at 3800-4000 which is cruising speed! Thanks
Your build is kinda odd ball.... it's not daily we see a 468ci build using LS3 heads going into a boat.
It's plenty of guys here you can contact for a cam. Cam Motion, Martin Smallwood, Patrick G, Geoff at EPS, Brian Tooley, Ed Curtis... even Tony Mamo might spec you a cam for those heads. I would call all those guys. Tell them exactly what you are doing etc... and go with who makes you feel most comfortable.
