what size crank are in the 6.0 iron blocks
Are you asking if they're the same stroke or if they're the same size, b/c the answer is different. They are the same stroke 3.622, that is correct. However, the LQ9 cranks were not the same size as LS1 cranks until 02+. In the earlier years, the crank was a bit longer, I believe, or something of the sort which caused compatibility issues when mating up to the tranny in an LS1.
