Oil Leaking from Crank on a ls2 402?
Guest
Posts: n/a
I have a LS2 402 with an Eagle crank in it.It is leaking oil from the plug in the back of the crank.
My question is how do I replace the plug and why will this fix the leak?Will a stock LS1 plug work?The plug that is in there looks straight.Why is it leaking?
i had the same problem with mine... mine you could see was slightly burred though. i'd say just have a good shop put another plug in it. stock would be fine, i think it's all the same size. that's what i did. not a drip now!
