Warhawk Makes More Power
Old 04-11-2007, 03:28 PM
Collections Removal
MerlinPro's Avatar
Default Warhawk Makes More Power
For the latest round of tests, see what a cam change on our 427 mule accomplished:
http://www.worldcastings.com/
Old 04-11-2007, 03:36 PM
Stang's Bane's Avatar
To be honest, I was not impressed.......until I noticed the heads LS1x Very nice results.
Old 04-11-2007, 04:41 PM
71CamaroLS1's Avatar
Big time power for as-cast cathedral port heads. It'll be very interesting to see what you get with the LS7x heads!
How big a cam did it take to get those results? My guess is you have to be close to a 250 @.050 intake lobe to get a 6500 RPM peak with cathedral ports ...
Will the warhawk block work with LS7 dry sump oil pump and pan?
Old 04-11-2007, 05:24 PM
Hard Core Z28's Avatar
That is a monster. Got to start saving.
Old 04-11-2007, 06:05 PM
Quickin's Avatar
MerlinPro,
The heads you used on this engine, what's the flow numbers? Just wondering what LS7 heads might offer it by way of power increases.
Basically this 427 is a ~500 RWHP stroker engine, what do you expect as an increase with LS7 heads?
Old 04-11-2007, 06:18 PM
Originally Posted by Quickin
MerlinPro,
Actually, this would likely be more like 530+ rwhp through an M6 - once again, using unported heads. For those of us who follow the old-school motors, Bill Mitchell seems to be very good at continually tweaking his combos until they produce remarkably good results for the money, even if his cast heads aren't always quite up there with the best high dollar CNC efforts on the flow bench.
Old 04-11-2007, 06:40 PM
C Murda's Avatar
MerlinPro,
ya im interested in this info as well...flow numbers on the ls1x heads AND ls7x heads so i can choose what i really want or need for that matter.
Old 04-11-2007, 06:44 PM
Quickin's Avatar
Yeah, I was just figuring through an A4 tranny. 614 @ 18% loss = 504 RWHP. But I'm wondering...........
The compression on this 427 Warhawk is the same as my 436 and the cubes are basically the same too (9 cubes different), my heads are cheezy 304cfm LS1 ported heads, and a stock TB with an LS6 intake. Mine is also 5 years old with basically the same power as the Warhawk 427, and the Warhawk 427 in question has a much better intake and MUCH MUCH better flowing heads. My cam in my 436 is tiny as well.
Whats the deal?????
Old 04-12-2007, 08:17 AM
Actually the Warhawk in question has worse flowing heads. They peak at 295. So once again I am very impressed with these results.
Flowbench #'s do not always=Horsepower
Old 04-12-2007, 08:18 AM
Collections Removal
MerlinPro's Avatar
71Camaro,
The cam specs are right on the dyno sheets posted on the site-you're very close-and you can compare specs to the first tests sheets. Yes to the dry sump.
Quick and Murda,
To be very frank-we don't have finalized flow numbers on both head designs. We fully understand the customer's need to be able to "shop" numbers among mfgs and porters and choose what he needs. Mitchell has never subscribed to publishing data about flow numbers (they're not even on our sites) but has come to accept reality and we'll start a program to do all our stuff soon.
For 20 years, Bill always measured his porting ideas by his ETs and later-by dyno results. If the dyno told us these numbers were seriously down, we'd have gone into the heads. We are really trying to get these parts and engines out to guys and have trimmed away the extensive test procedures needed for specs. We feel the heads are good to go as designed (and still be very competitive with the other quality designs out there) and the porters can make them exceptional. We really will flow these all and they'll be the production pieces, not prototypes.
Our priority is to beat the **** out of this mule. I incorporate any special build methods or changes into the instruction sheets for the blocks and heads, and later the engines.
Possibly today or surely tomorrow the 7X heads will run (same cam as seen now) and we'll show you results or tell you about any issues. The block and heads continue to work well together.
Old 04-21-2007, 07:36 PM
Any progress to report on the 7X test, MerlinPro?
Old 04-22-2007, 07:37 AM
Collections Removal
MerlinPro's Avatar
They haven't begun yet due to shop being remodeled. May take place late this week.
Old 04-22-2007, 08:21 AM
Bring the Noise's Avatar
When you go to the LS7's are you going to go back to the .600 240/246 that was used in the first test?
I'm guessing with the LS7's 1.8" rockers the lift is going to be close to the .635/.635" on the first cam and well... .675/.695 with the second cam.
Will you try with a larger split then the 2 that were used with the ls1 heads?
How much for a 389 using the warhawk block and ls7 heads and say a small 232/238 cam?
Oh and congrats on the very nice numbers this combo is showing (even in the initial tests).
Old 04-22-2007, 06:55 PM
Collections Removal
MerlinPro's Avatar
Bring,
As far as I know, we're keeping the second cam in place with the 1.8's. Bill has been away and he calls the shots on combos. Stay tuned, I'll post when we pick it up again.
We have no price idea on completes yet as I mentioned. This testing is designed to find good combos for what the market wants and what we can safely warranty. Of course, with the Drag line up we sell that's not an issue, but Warhawk's not there just yet. I believe we're going to sell from 427 on up. Bill likes displacement.
-And thanks for the really kind words. We're trying for better results.
Old 04-24-2007, 04:56 PM
ace67's Avatar
Have you relesed the tall deck block yet ? or is it another 2-3 week away as useal ;-)
Old 04-25-2007, 07:44 AM
Collections Removal
MerlinPro's Avatar
ace,
I WISH it would be 2 or 3 weeks. Latest world is around end of July.
Old 04-25-2007, 04:56 PM
ace67's Avatar
Too bad i really want one of these but i cant wait forever
Maybe better to just buy a LS7 and some NOS and be done ......
Originally Posted by MerlinPro
ace,
Old 04-27-2007, 06:37 PM
Collections Removal
MerlinPro's Avatar
A new information update appears on our homepage links to the Warhawk test pages-dated 427 (naturally).
Old 04-27-2007, 07:42 PM
Juiced's Avatar
Congrats Merlin,
You have more mail!
Old 04-28-2007, 09:55 AM
Bink's Avatar
LS7X heads and a Drag pack......can't wait to follow this setup!!
Quick Reply: Warhawk Makes More Power
