crank polishing
Old 04-14-2007, 04:44 PM
fstls2camaro's Avatar
Default crank polishing
i got my crank polished can i use standard bearings?
Old 04-14-2007, 05:50 PM
Boosted LS1's Avatar
You mean the journals were polished? If so standard bearings will be fine assuming the crank journal diameter hasn't shrunk. It won't have shrunk if it's just had a simple polish but it will be much smoother to the touch.
Boosted.
Old 04-14-2007, 06:53 PM
GEN3Typhoon's Avatar
The engine needs to be assembled and the proper clearances set.
No one can tell you what bearing to use without checking the main bores with the caps properly torqued.
Old 04-14-2007, 07:03 PM
brad8266's Avatar
Quick Reply: crank polishing
