Hi Tech cam
Hi Tech cam
https://www.hitechmotorsport.com/sto...cb7ca7a8eaaf3d
Anyone ever run that one in their ls1/ls2? How did you like it?
Originally Posted by Stang's Bane
It is just a reverse split cam. Should work pretty well if you have a pretty good exhaust system and an average intake system. Depending on your mods, a standard split may work better or even a single pattern. The whole thing is a combination.
This will all be on an LS2 GTO A4.
Personally, I have no first hand knowledge of the cam. It was just coincidence that I happened to see his post about the same cam you mentioned.
Originally Posted by TA455
There's a guy on the GTO forums that apparently isn't too happy with it in his LS1. http://ls1gto.com/forums/showpost.ph...50&postcount=9
