What pistons are you L92 stroker guys running??
Is there an off the shelf piston avilable for the L92 stroker guys? Basically a 4.065b 4.0s 6.125r with a flat top?
If not what are people on here using?
Originally Posted by Forteen3GT
HKE ordered a bunch from Diamond.... flat tops for L92 blocks. I have a set made for my LQ9 6.0 block.
I couldn't find anything just wondered if someone knows of something.
That's cool but it doesn't answer my question. I'm wondering if there is an off the shelf piston not a custom piston avilable. I know diamond will make them but they are 50% more money being a bore change (4.065 not 4.060).
no... these are shelf... the L92 Block is a 4.065 bore.... pistons are slightly larger for a good hone. If you are using an L92 block.... then you are good to go! My setup is on a 4.030....using the same tops or mold as the L92 block pistons. The reliefs are just closer to the edge.
My L92 427c.i. has 4.068" Manley Forged pistons in it. They have a Scoggin Dickey Part number. Call Manley and ask for a man named "Pride". He can fill you in.
