LS2 GTO 40? plus nitrous Question
As I understand it if you bore out the stock block to 4.0005 you get a 402/403 most say a 403. How many people have this setup on this board. I would like to know what setup you have and your N/A + Nitrous added numbers. I was explained based on the build, tuning, and timing required it would run around 430rwhp N/A and 570-580rwhp with a 150 shot of nitrous running through it. Does anyone have better numbers or are you running a larger shot. Just inquiring for some answers so I know what to expect and gather ideas before they tear into the block. Thanks!
to get your 364 to a 402 you need to change the crank to a 4''. stock i believe is 3.622.
if 430 rwhp is your your goal na you can do thet effortlessly with your 364. hell even a little ls1 347 can do that without to many problems. search around and read some posts youll read some crazy ****!
good luck
good luck
u can do this easy with a 346-i spray 175 on my 346 with **** heads and a 224-228 cam to get 540-550 rwhp=
so with a set of killer heads and a different camshaft i dont see why not 30-40 hp is not around the corner-
also on a standard short with the same comp ratio as it come out-how long it will last is a different story all-together-
I was too vague and I apologize. What I was saying is with a 403ci LS2 which is the stock block stroked to a 4.005 with forged internals, I was wondering what people had a similar setup and what numbers they were getting, as well as with nitrous added. Some had told me the lower numbers of 430rwhp without spray and 580rwhp w spray. But I have heard from a few shop owners recently that those numbers are real low. Just trying to get a baseline area of where i will be. Thanks for the responses thus far.
a 403 with all the proper supporting mods should make 500-550 rwhp depending on the setup. 430 would be pretty low for a 403. as far as nitrous goes just take what ever the engine makes and add xxx hp for the nitrous.
430 hp is more like cam and bolt on car power range.
