metal build up on drain plug???
ok so i have a 2000 ls1 and everytime i change the oil there is a small build up of metal on the magnetic tip of the drain plug. is this normal? its not lot and its not chunks either.
thanks,
ryan
thanks,
ryan
i was thinking it was normal as well. its like the build up you would find on the magnet of a rear diff cover if you were to doing a differential service on your 10 bolt. but im just checking ot make sure.
ryan
ryan
