Ordereing Custom Ls3 Pistons And Need Some Info
i am ordering pistons for an ls3 and can not find the cylinder lenth anywhere. also what is the best piston to deck spec to run withthese motors in a boosted application?
thanks
shane
thanks
shane
OWN3D BY MY PROF!
Why do you need the cylinder length? All you should need is stroke, deck height, rod length, and deck clearance. You measure the deck height, and then plug in what stroke crank and rods you are using. The deck clearance is your choice and you figure the compression heigth from there.
For example:
amount the piston is in / out of the hole aka deck clearance = (1/2 x stroke + rod length + compression height) - deck height
Example:
I like a zero deck for a multitude of reasons... so
0 = 1/2 x 4 + 6.125 + x - 9.240 = 1.115 compression height.
For example:
Example:
