Oil Pan Gasket LQ9 motor
Old 12-21-2007, 07:55 PM
bluethunder364's Avatar
Default Oil Pan Gasket LQ9 motor
Do most people use the one from GM or has anyone used a Felpro? I'm sure the Felpro would be less money, but want to make sure it will do the job. Comments welcome. Thanks
Old 12-21-2007, 08:05 PM
jay_lt4's Avatar
never used a new gasket,, i have re-used the factory gasket several times
Old 12-22-2007, 01:43 PM
Really!! Did you redo the seam sealer in the corners for the front cover? The torque must be critical also. Allright I'll try it.
Old 12-22-2007, 10:45 PM
jay_lt4's Avatar
i have reused the timing cover and oil pan gaskets several times and i never used sealer at the corners and have not ever had a leak,, you could use a dab of sealer at the corners it isnt going to hurt anything
make sure you use the correct tools to align the oil pan and front cover, i have access to the gm gen 3 engine tool kit and use it every time to align the oil pan and front and rear covers.
Old 12-23-2007, 11:54 AM
What are the special align. tools?? Can I purchase them at a dealer? Cost??
Thanks
Old 12-23-2007, 01:18 PM
sroach20's Avatar
i did not use the tools on mine and it does not leak. just use a ruler and measure all around. it was cheaper to buy the oil pan gasket from an online gm parts house than getting a felpro from an auto store.
Old 12-24-2007, 07:40 PM
Thats good to know, thanks for the info.
Quick Reply: Oil Pan Gasket LQ9 motor
