Head Gasket Question
I have an LQ-4 with the dish pistons, (6.7cc) and will install a set of L-92's that have a confirmed 68.5 cc chamber. With a .010 over deck piston what would be my final compression ratio if I use a LS7 head gasket #12610046? Or should I use a stock LQ-4?, Would like to come out with a CR of close to 10.0 I'm thinking that both GM stock gaskets would come close to a final compressed thickness were as say a Fel Pro #1161L may come in a little thicker. Although that is also a MLS type gasket as well. HELP !!! Thanks
