LS2 main bearings
LS2 main bearings
what is the difference between all theses main bearings ? some say -.010. one says standard , ect ..
http://www.sdparts.com/catalog/lsgen...eBearings.aspx
The suffix at the end of the part # (.001, .010, etc.) refers to the undersize/oversize of the bearing set. Those part #'s listed on that link are Sealed Power part #'s. The Clevite main set is MS2199H.
COmp cams LS2 Timing Gears and Chain
a few problems with the Timing gear on the Crank , there are 3 different Key ways in the Sprocket , and counter clockwise from the keyways about 2 teeth there are a rectangle mark a, triangle mark and a circle mark .. what one do i align this up with ? Cause the Stock gear and the part that makes the old pump turn is all one peice , but with the gear i bought from Comp its 2 peices , so could somone help out here i would appriciate it
pics are below ..
here is a link or what i got
http://cgi.ebay.com/ebaymotors/COMP-...spagenameZWDVW
pics are below ..
