What kinda of Pulley puller do i need to pull the stock timing gear off the crank
what kinda of pulley puller do i need to pull the stock gear off the crank ? from a ls2 Crankshaft ? so that i can install my new comp gear on the crank and the spacer for the oil pump .
https://ls1tech.com/forums/generatio...ng-policy.html
this one seems to be the best bet. i should have done my research first before going through 3 different gear pullers and damaging my pulley. =(
