LQ9 help
Old 05-17-2008, 03:27 PM
1bad2k's Avatar
Default LQ9 help
I have a 6.0 and 4L60E. Im thinking about doing a LS7 cam/springs/pushrods combo and throwing in a tbss stall or yank (if i can still get a good deal on one) and a tune. I have longtubes, corsa and cai. Any of you guys ever had this combo? what can be expected? any pros or cons of the LS7 cam paired with the tbss stall? i have considered a custom grind but not knowing much about what i need doesnt put me in a good spot on that. any info or knowledge that would help me make the best choice would be greatly appreciated. Its is my DD so i want a mild idle but good power gains. I also would like a badass tune, so any help in pointing me in the right direction for that would be appreciated as well. thanks a lot guys......Sam.
Old 05-17-2008, 10:47 PM
Richard@WCCH's Avatar
That cam should work well with a 2600 stall converter and a tune. You could probably get away with a stock converter using that cam and the idle will be very nice. Those cams also work well with boost.
Good luck,
Richard
