105mm Air filter.
Old 08-11-2008, 05:25 PM
jermzz's Avatar
Default 105mm Air filter.
So I have an accufab 105 mm tb and I was thinking about ditching the stock air intake system / box and just strapping this baby directly to the TB.
think it will get enough air this way, or should I get a 4" tube and try to adapt it to the stock intake lid system?
http://store.summitracing.com/partde...925239+400171+
thanks!
summit part ru-2510 if it wont load.
Old 08-11-2008, 06:42 PM
FireChickenws6's Avatar
K and N actually has a set up kinda like what you are thinking but they use a long oval type for clearance. As long as you have it tuned right and it will fit under the hood you should be ok.
Old 08-11-2008, 08:54 PM
jermzz's Avatar
I see. yeah there's more then one. The problem is that I need a 4" inlet cause it's a 105mm TB.
if anyone knows a part number that would be great.
thanks
Quick Reply: 105mm Air filter.
