Generation V External Engine LT1 Bolt-Ons | Intakes | Exhaust | Ignition | Accessories
L83 L93 Gen V How to Kill a Vacuum Pump
Old 09-27-2016, 05:21 PM
  #41
1978LT1's Avatar
I just wanted to know a little bit of technical info about the l83 engine. I would want somebody to fact check this.
Like the LS engines, LT engines are also the same dimensions. So the 5.3 has the same dimensions and crank bolts etc. So is the 5.3 8 bolt too? Has anyone checked? The reason i ask is to mount the correct flywheel and clutch combo..for a manual.
Do any one of you guys run headers? Are there any out there for this swap? I do see a lot of truck headers and camaro headers but i am sure if they will fit older cars?
Old 10-08-2016, 10:49 AM
  #42
mzrico's Avatar
Hello. My flex plate is 8 bolt patern. I'm running factory manifolds. Good luck.
Old 12-15-2016, 03:00 PM
  #43
Mike Blanco's Avatar
Do they make a mechanical/belt driven vacuum pump for the 6.0L LQ9? I know I could go and get an electric vacuum pump, but would like to try to keep it a bit more clean and considering a belt driven unit, if that is a thing....
Old 12-16-2016, 02:15 PM
  #44
mzrico's Avatar
I have to say no.
Old 03-21-2017, 09:02 AM
  #45
MEAN_SBC's Avatar
So did you get it running and the vacuum measured yet? I'm really wanting to remove this pump.
Old 04-07-2017, 08:54 AM
  #46
mzrico's Avatar
Hello. I have been busy painting the 69 Camaro. I went with the LT1 intake, it has the port for power brake vacuum as the LS type intakes. I won't be able to measure the truck intake vacuum. I did turn the engine on with the truck intake and the vacuum at the emissions fumes valve is very strong. I have no doubt it will be enough for power brake booster.
Good luck.
Old 04-07-2017, 09:12 AM
  #47
mzrico's Avatar
Default 6L80e in a 1969 Camaro
Very little information is available with regards to the 6L80 in first gen Camaros. I was able to fit my L83/6L80 combo in my 69 Camaro. No cutting of the floor. I made some minor changes to the firewall (small endentation to give the high pressure fuel pump guard bracket clearance), I moved the fuel injector wire plugs off their brackets and against the intake, and hammer up the metal slightly at the middle very front area of the transmission tunnel. The original subframe and engine tower were modified to accept the engine.
Attached Thumbnails L83 L93 Gen V  How to Kill a Vacuum Pump-img_20170406_210123_hdr.jpg   L83 L93 Gen V  How to Kill a Vacuum Pump-img_20170406_210400_hdr.jpg   L83 L93 Gen V  How to Kill a Vacuum Pump-img_20170406_210949_hdr_kindlephoto-118047769.jpg
Old 06-27-2018, 11:25 AM
  #48
Chris Meehan's Avatar
Any new information on how the Vac was changed out for the brake booster as i really want to change out my vac pump..
Quick Reply: L83 L93 Gen V How to Kill a Vacuum Pump
