Generation V External Engine LT1 Bolt-Ons | Intakes | Exhaust | Ignition | Accessories
gen5 throttle pedal wiring diagram.
Old 12-08-2016, 08:37 PM
brandon6.0's Avatar
Default Ls swap Corvette/truck throttle pedal wiring diagram.
Hey i purchased a standalone speartech ls swap harness it was wired for a vette gas pedal. Since im using a truck gas pedal i had to repin the harness for correct throttle movement. Without the correct wiring u will not have any throttle movement. So i figured i would post up a diagram on wiring for others to use.
Truck etc diagram:
A= purple
B= light blue
C= tan
D= white/black
E= dark blue
F= brown
Corvette etc diagram:
A= purple
B= light blue
C= tan
D= dark blue
E= brown
F= white/black
Old 01-16-2017, 08:04 PM
Christian Avanti's Avatar
Default Diagram
Originally Posted by brandon6.0
Hey i purchased a speartech harness and they used a corvette throttle pedal. Since im using a truck throttle pedal i had to rewire it. So i figured i would post up a diagram on wiring for others to use.
Truck etc diagram:
A= purple
B= light blue
C= tan
D= white/black
E= dark blue
F= brown
A= purple
B= light blue
C= tan
D= dark blue
E= brown
F= white/black
Can you post a picture of the diagram your referring too?
Old 02-20-2017, 06:12 PM
brandon6.0's Avatar
i don't have a pic or actual diagram. i know this bc i had a corvetter wiring harness and had to repin it for a truck pedal.
Quick Reply: gen5 throttle pedal wiring diagram.
