Generation V Internal Engine 2013-20xx LT1
EcoTec3 engine family... specs, photos, discussion and more [GMHTP]
Old 12-22-2012, 03:47 PM
WarShrike's Avatar
Direct injection, superior cylinder head airflow characteristics and the VVT can make up for that displacement. DI in small displacement motors has helped a good bit on the torque output. It will be hard to do a stock for stock comparison but it will be nice to see the output.
Old 12-25-2012, 09:12 PM
Bumpin' Yota's Avatar
Another thing - in diesels, which use either direct injection or indirect injection into a swirl chamber inside the head, the injectors are a wear item typically needing replacement after 100k miles or so.
Is this going to be the same for these new DI engines now too?
Old 01-05-2013, 11:40 AM
T.Man's Avatar
Diesel injectors see much, much higher cylinder pressures than an N/A DI motor. However, the injector seals will need to be inspected periodically.
Old 01-05-2013, 03:53 PM
Jenson's Avatar
Sure looks a lot easier to run that accessory configuration/AC compressor in a boosted F-Body
Old 07-01-2013, 07:46 AM
Awake455's Avatar
I'm curious to see why the 4.3 has a noticeably more cluttered accessory drive system (alternator and coolant pump). From looking at them it looks to be the same brackets in all three photos. The V8s have the tensioner on the driver's side and no extra idler pulleys. Looks quite simple and effective. The 4.3 has the tensioner on the passenger's side, a grooved idler, and a backside idler.
I'd like to think GM wouldn't want to design two drive belt arrangements, one more complex than the other, for the silverado. If there's room for that simpler drive belt arrangement in the full size trucks on the V8, it should be much more so on the V6. I'd hafta conclude that they are going to stuff the 4.3 in something with an engine bay that necessitates the change.
Old 07-01-2013, 08:49 PM
Krom's Avatar
The accy drive on the 4.3 is 5" or so further rearward than the V8...
It may be needed to clear the front suspension in the trucks
Old 08-28-2013, 06:17 PM
midnightbluS10's Avatar
Originally Posted by Bring the Noise
3 Questions...
1. Are they all dry sump (like the Gen V LT1)?
2. What is the bolt pattern on the crank (old 6 bolt LS1,2,3; 8 bolt LSA; or 9 bolt LS9).
3. Is the V6 a 90 degree or a 60 degree (cause the 90's usually need a counter balancing shaft)
I'm going to guess that the standard motor for the 1500 series (1/4 ton) will be the 4.3L V6, with the 5.3L V8 as the option motor.
And the 6.2L will be only used in the Tahoe/Suburban line and the 2500 series (1/2 ton) or larger models.
1/4 ton fullsize trucks? Never heard of them. I always knew them to start at half-ton and go up from there, no matter what Co. it was.
1500=1/2 ton
2500=3/4 ton
3500=1 ton
F150-1/2 ton
F250-3/4 ton
F350-1 ton
Same with Dodge
Old 03-24-2015, 07:38 AM
dlbarb's Avatar
Default Aftermarket Swap Potential
Any information of developments on these engines yet. I am seriously wanting to put one of these in an older Toyota mini 4x4. The old vortec was a popular option but this should be far superior and an easier fit due to not having a distributor in the back. Anyone heard anything on retro fit or support on electronics for swap potential?
Old 03-16-2017, 10:43 AM
dlbarb's Avatar
I can't believe this has not exploded yet.
Old 03-18-2017, 07:32 AM
truckdoug's Avatar
are you talking about the LV3?
I'm getting ready to swap one. To answer some of the earlier questions, it's wet sump, LSA/8 bolt crank pattern, 90* with a counter balance shaft.
afaik there are no aftermarket harnesses available. HP Tuners supports the e92 computer.
Thats about as far as we've gotten.
So little time, so many projects!
Old 05-11-2017, 04:47 PM
mark underwood's Avatar
Howell makes a Harness and flashes the computer for the LV3
208 motorsports makes a harness or modifies yours. and flashes.
Comp cams is making me the first Aftermarket camshaft for this motor to date and i have my heads getting bigger valves and ported.
Old 05-12-2017, 02:21 PM
  #32
MuhThugga's Avatar
From what I have seen, they are still relatively expensive to pick up.
Quick Reply: EcoTec3 engine family... specs, photos, discussion and more [GMHTP]
