Noob, w/ ported head stuff inside.
Hello, I just signed up today so I guess I'm a noob. I currently have an 84 SVO and an 85 Turbo Coupe, but a lot of friends have LS cars and I am a big fan of these engines.
Anyways I have been porting heads [many different kinds] for a while and I recently did my first set of LS1 heads for someone and paid to have an intake and ex runner flowed. They were 6.0L "317" truck heads here are some before numbers I found online of the exact casting... dumbass I am... should have flowed them before, the guy didn't seem all that interested in doing that, till they were done...
Casting Number 317, 035
Head: 2001+ LQ4 and LQ9 6.0 Liter Truck
Material: Aluminimum
Part Number:
12562317 -LQ4
12572317 -LQ9
12572035 -LQ9
Combustion Chamber Volume: 71.06cc
Compression Ratio: 10:1 LQ9 Flat top pistons
Compression Ratio: 9.6:1 LQ4 Dish piston
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Stock Head Flow Numbers
Chamber 71.06cc----0.100---0.200---0.300---0.400---0.500---0.550---0.600
Intake 210cc----------66------142-----196-----228----236---238----240
Exhaust 75cc----------59------104-----137-----155----167---173----177
Here is after #s. Stock valves still etc.
INT
.200" - 147.3
.300" - 212.6
.400" - 251.5
.500" - 272.4
.600" - 271
.700" - 272
EX
.200" - 117
.300" - 154.5
.400" - 180
.500" - 201
.600" - 219
.700" - 222
& some pics...
http://ohreally.mnsi.net/ls1bowl1.jpg
http://ohreally.mnsi.net/ls1bowl.jpg
http://ohreally.mnsi.net/ls1bowlported.jpg
http://ohreally.mnsi.net/ls1intrunner.jpg
http://ohreally.mnsi.net/ls1intported.jpg
http://ohreally.mnsi.net/ls1exrun.jpg
http://ohreally.mnsi.net/ls1exrunported.jpg
http://ohreally.mnsi.net/ls1headex.jpg
http://ohreally.mnsi.net/ls1runnersported.jpg
http://ohreally.mnsi.net/ls1done.jpg
I'm just wondering how I did.. you can't see from the angle of the pics, but I did make a hole [and removed a lot] where the rocker bolt boss was.. I made a plug for the hole and then blended it, and had him flow test it w/o the plug and with.. and the difference was NIL....
Just wondered how these numbers looked, Thanks.
Part Number:
12562317 -LQ4
12572317 -LQ9
12572035 -LQ9
INT
.200" - 147.3
.300" - 212.6
.400" - 251.5
.500" - 272.4
.600" - 271
.700" - 272
EX
.200" - 117
.300" - 154.5
.400" - 180
.500" - 201
.600" - 219
.700" - 222
& some pics...
