Built ls1 FD rx7
Old 12-26-2013, 10:44 AM
das stig's Avatar
Default Built ls1 FD rx7
Hey guys,
I am not new to the tuning scene at all (owned 3 all early 90's built miata's last one was dyno'd at 250whp, a show quality g35 coupe, gti fully built, 2.5rs coupe, and e36 m3) but this is the first time getting into something with an LS as well as the first time getting into an RX7 so I'm in new territory.
Going to look at this ls1 FD sunday and wanted some advice on what I should ask, be looking for, or anything I should be concerned about?
Thank you!
Specs:
ls1 swap 5.7 Liters Bore & Stroke (in): 3.90/3. Compression Ratio 11:1
T56 mt swap, was an auto until 2 months ago (hasn't been tracked with the mt)
Diamond Pistons Eagle Rods / Stock Crank Comp Cam, Custom Ground Comp Springs & Retainers
Throttle Body: 85mm
BBK Injection: 60lb Injectors
Fuel Delivery: 255lph
Walbro Engine Management: HP Tuners Ignition
Stock LS1 Ignition Spark Plugs: NGK tr6 v-power
Hinson Long Tubes Custom Rods Cars 3" Mandrel Exhaust
Hinson Radiator SLP
High Flow Oil Pump
Headstuds
Custom Ground Camshaft Info: Intake .643 Exhaust .598 Valves
ARP (wet) Nitrous: 100
Ram Clutch
Has Line lock
Engine from an 02 ss Camaro with 3k on the build.
Also power steering, dvd player, full sound system, clean body, no a/c
The guys says he's run a 1090 in the 1/4 mile with it but only took it out twice.
He's selling it for a great price, and I have a few grand of "oh ****, things broke" money saved up... but I want to get general opinions on it. Ill be using it as a summer fun car probably not take it to the track (maybe once or twice) and honestly not drive it Insanely hard, just occasionally
Old 12-26-2013, 11:50 AM
das stig's Avatar
Pictures during the process of the swap, swap was back in 09.
Quick Reply: Built ls1 FD rx7
