my lt1 wont breath
Old 03-24-2008, 10:16 PM
atombombz28's Avatar
Default my lt1 wont breath
my lt1 is not gettin air. i replaced the maf and i got a new intake and filter.it helped but still having problems. if anyone can help that would be great
Old 03-24-2008, 10:18 PM
sworaz's Avatar
Need some more info....how do you know it's not breathing? Is it having idle issues? Did you run codes?
*edit* Welcome, and you posted in the wrong section.
Old 03-24-2008, 10:21 PM
well i have a feul/air ratio gage and when i first start my car its fine then when i drive after 4ooo rpm it doesent want to accelerate anymore
Old 03-24-2008, 10:32 PM
sworaz's Avatar
Check if it's throwing codes. Sounds like a partially clogged cat...if you still have them.
Old 03-24-2008, 10:35 PM
i did the codes and it was coming up egr and left o2 sensor.....and yea it still has cats
Old 03-24-2008, 10:41 PM
sworaz's Avatar
Just do some searching in the lt1 tech section for the codes it's throwing. I'm sure you're not the first one to have this issue. Good luck.
Old 03-24-2008, 10:47 PM
thanks man.
