Nx bottle question
Nx bottle question
I got a NX bottle off of someone the other day and picked up bottle nut adaptor off ebay and realized nx uses a 2 piece design. I need to get the plastic washer for it anyone one the size and also does NX use something else instead of it since its a 2 piece design (like rubber or something). Thanks in adfance
Do you have a picture of the valve? One style uses a teflon washer that rests against the flat face of the threads and the other is a nut & nipple that seals with a pressure fit. If it's just a plastic washer that you need you can go to a welding supply place and pick one up there.
nipple fits into the bottle nut
this is what i show on nx's site under instructions
Insert the bottle nipple (3) into bottle nut (4) and securely
tighten on the bottle valve. (See Illustration A.)
http://www.nitrousexpress.com/Instructions/stage1.pdf
So maybe no washer?
So maybe no washer?
