fitting for spectra premium fuel tank
Old 10-17-2008, 09:14 AM
SUPERBOOST's Avatar
Default fitting for spectra premium fuel tank
Does anyone have a part number and place to buy a fitting to go on the spectra premium efi tank for chevelle.The feed line is straight 5/8 18 theads with a male flare like on an an flare.They send you a fitting from that to a barbed fitting for a push lock hose but I would prefer to go straight to 6an line.
Old 10-17-2008, 11:21 AM
ryanvv355's Avatar
I had a buddy of mine weld a couple -06 fittings on the SPI fuel sender unit.
Old 10-17-2008, 01:58 PM
6spdgto's Avatar
pure choice motorsports sells a stainless compression to AN for both lines.
McMaster-Carr you can buy a stainless compression to pipe threads and then buy an AN to pipe thread converter from Summits or Jegs (a little cheaper and a little longer in length) for both lines
Old 01-08-2015, 06:15 PM
cpd004's Avatar
Are compression fittings the only way to go or is there something available that'll work without cutting the lines on the tank? Something that gets to -6 like the original poster asked.
Old 01-09-2015, 12:35 PM
ryanleiker's Avatar
That fitting on the Spectra tank is a 45* SAE flare. It will be very difficult for you to find a fitting that you will like to fit this.
When I got mine, I was worried about warranty and such and called them and they said, that cutting that fitting off and flaring your own on would not affect the warranty at all. So I cut it off and put on an inverted flare tube nut, then adapted this to -8 AN. I should have just done a 37* AN flare tube nut at the time, but I didn't have the flaring tool. Also, be aware that these lines are much harder than, say, a brake line from the parts store, so be very intentional with your flaring and double check them so they don't leak.
Old 01-09-2015, 06:54 PM
cpd004's Avatar
I decided to use this
http://aeroquipperformance.com/i-165...o-male-an.html
I just had to grind it down slightly and it worked perfectly.
For the return, Earl's makes a 5/16" pipe compression to -6AN male. I cut the barb off and used this.
Quick Reply: fitting for spectra premium fuel tank
