2.02/1.60 worth it with my setup?
I plan on going with a stock bottom end(rod bolts, main girdle, main studs), with CC306, ported Stock heads and Ported stock Intake manifold...
Would it be worth it to install 2.02/1.60 valves? I know it would benefit from it but would it actually be worth the money to have my heads machined and the whole 9 yards...?
And to go ahead and get this out of the way... Im not buying aftermarket heads... budget build..
Its done quite often on stock heads. I was thinking about it on my heads but I spent the money on porting instead, so when I build a forged 355 I will have it done
I'm doing a similar setup and my engine builder said basically that it is not worth the money for the tiny gains if any you will see. After the long explanation I see what he means. If you have the money to blow see what happens but for a budget build forget it.
LS1TECH Sponsor
The stock valve setas are only 2.00/1.56 so if you machine the seats as large as possible, a 2.00/1.56 valve fits perfect.
If you use a 2.02/1.60 valve, you are just placing a larger valve in front of the seat and same size hole so the air has to go around more valve diameter before entering/exiting the cylinder. You will lose flow and HP over a 2.00/1.56 valve.
Lloyd
Lloyd
OWN3D BY MY PROF!
The best thing you could do is get a set of stock LS1 valves (2.00 / 1.55) and have the guides switched out. Having the guides switched should cost about $150. You can get a set of LS1 valves for about $30-50. Then, add the $150 = $180-200. That's less than you'd spend on a set of 11/32 aftermarket valves. You'll have a larger valve than stock, thinner stem diameter that'll flow more air, and do it on a budget.
You also either have valve springs or will need a set. You can order a set of Patriot Golds (LS1 ones) for $250 and be set.
