Ok how loud and streetable is the 4303 really?
If zero is stock volume how loud out of 10 is a magnafuel 4303.They say it can be used as a street pump but is it going to get on my nerves or not.
My other option is intake pumps assume they would barely be louder than stock in tank?
But do like the idea of one big external seems like so easy to service and really should be running bit lines and all that with my setup.
But if this pump is really like an 8 /10 I might not like it very much.
At most 4-5 they are very streetable....but if you can use intank pumps for your setup they are the most reliable and clean solution. Check out our Stage3 street kits.
Nate
Nate
