wot switch failure
Old 10-26-2008, 05:27 AM
WH97Z's Avatar
Default wot switch failure
how much damage can be done if wot switch fails and nitrous stays on after letting out of the throttle?? any ideas?
Old 10-26-2008, 09:19 AM
TJ
TJ's Avatar
if the switched fail, then no power should be going to anything.
if you ran current through the switch(use a relay) and it arched or welded itself, then the nitrous could have been on with the throttle closed.
kinda vauge post. hard to say. if the motor is running, id say everything is fine.
change the plugs and change the oil and see what happens.
Old 10-26-2008, 09:48 AM
98childsta's Avatar
Do hope you have a wet kit, if you have a dry kit i would definately do the following what TJ said I would also recommend you to adjust your toggle switch cause maybe its getting stuck somehow to stay on.
Old 10-26-2008, 10:41 AM
Jditlfm's Avatar
A window switch would kinda help as long as you knew you wot switch was bad.
Old 10-26-2008, 05:57 PM
WH97Z's Avatar
did an oil change and will do plugs this week. motor sounds ok and runs fine. thanks for the tips. oh and it is a wet kit
