**TTP Cam Install Special Back Again**
- TTP Custom Camshaft
- Patriot Gold Dual Spring Kit
- Trick Flow Hardened C/M Pushrods
- GM OEM Gasket/Bolt Installation Kit
- LS2 HD Timing Chain
- Royal Purple or Mobil 1 Oil Change with Filter
- GM Dexcool Coolant
- Full Professional Installation
- Full Custom Dyno Tune Including Dyno Time, WOT, and Part Throttle Tuning
FBody, GTO, CTS-V $1950 (-$75 if LS2 Timing Chain equipped 05-06)
C5 or C6 $2100 (-$75 if LS2 Timing Chain equipped 05-06, Add $50 for LS7 timing sprocket for 07-08 Single Bolt Cams)
