Internals & Balancing
Currently I have a 383 stroker with 4.0" crank and 6.125" rods with 3.91" pistons. I am thinking about migrating over those internals, minus the pistons, to a prepped LQ4 block. Is this possible or does the assembly need to be rebalanced for the 4.030" pistons?
Re: Internals & Balancing
No. The crank is balanced against whatever the pistons, rods, rings, etc weigh (reciprocating weight). Problem is if you go to larger pistons (weigh more), then weight will have to be added to the crank counterweights. Going lighter, no problem to take a little weight off the crank.
George
George
