Roll Cage Kuwait 2
Old 10-30-2008, 03:42 AM
DASHTI's Avatar
Default Roll Cage Kuwait 2
Alkooor Racing Team
Attached Thumbnails Roll Cage Kuwait 2-img_0275.jpg   Roll Cage Kuwait 2-img_0276.jpg   Roll Cage Kuwait 2-img_0278.jpg   Roll Cage Kuwait 2-img_0287.jpg   Roll Cage Kuwait 2-img_0296.jpg
Old 10-30-2008, 08:03 AM
allmotor's Avatar
Not too bad
25.5 right? nice work
Old 10-30-2008, 09:23 AM
allmotor's Avatar
by the way, most people in here are handling oriented so most people won't know what a 25.5 is
Looks good though, you should post this in the drag racing forum for more input.
Old 10-30-2008, 09:42 AM
Ironhead's Avatar
I guess I'll have to explain it then so you won't have to deal with the unwashed masses.
It's an SFI roll cage spec aimed at pretty darned fast stock-type (non tube frame) cars.
Old 10-30-2008, 09:47 AM
allmotor's Avatar
SFI spec 25.5 is for use in a full bodied car using the OEM floorpan and firewall with the OEM frame or uni-body construction.... good for 7.50 to 8.49 Seconds; 3,600 lbs. maximum.
Old 10-30-2008, 10:07 AM
z28bryan's Avatar
You're too humble and need to express your feelings more. Stop holding back.
-1 point for not just posting both sets of pics in one thread
+1 point for building a car in the Middle East. Are you serving over there right now? If you are then kick some ***.
Old 10-30-2008, 10:08 AM
allmotor's Avatar
Typical cage of drag radial guys, class in which min weight is 3400 lbs. and must run stock-style suspension. Maximum tire width 295 radials. Must be running well into the 7's in order to have any chance of competing.
Old 10-30-2008, 10:15 AM
allmotor's Avatar
There is not a US Military base in Alkoor to my knowledge, so I believe I can safely say no. I have a few friends in Kuwait, they have some sick cars over there My roomate 2 years ago is also from Kuwait and needed to buy a car here so he bought an FJ cruiser while he was waiting for the new G37 to be released
Old 10-30-2008, 07:06 PM
EchoMirage's Avatar
theres more to racing then just a straight line. you might be a 2 pump chump, but i last longer then 8 seconds.
Old 11-01-2008, 03:10 PM
Dex
Dex's Avatar
What good does this post do????
Old 11-02-2008, 01:18 PM
2001z's Avatar
Some people can care less about carving corners
Old 11-02-2008, 03:06 PM
EchoMirage's Avatar
some people can care less about stab & steer
Old 11-02-2008, 05:40 PM
2001z's Avatar
You should have bought a vette then.
Old 11-03-2008, 02:32 PM
JonCR96Z's Avatar
Or a cobra. He seems more like that type anyway.
